Engine system services required message is displayed with yellow warning triangle. NO check engine light, NO codes found on O'Reilly scanner.
When scrolling through the onboard diagsnostics (hold down read button on turn signal stalk and press the rear fog light button three times) it tells me there is a code set on every module except the SRS. I have had an independant shop reset the light but turns back on at second engine start. Also reset it by disconnecting battery ground, same result.
Is there a common failure point that will trigger all these codes? Bad ground?
Thanks in advance for any help! Nearest Volvo dealer is 120 miles away.
Allen
'01 S80 T6 186K miles
