1997 850 power windows
sbanks01
Year and Model: 850 1997
Post by sbanks01 »
I am having problems with rear driver side and front driver side they won't go down but both windows on pass. side work how can I fix this and it isn't master switch I changed that already
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Did you checked fuses & relays?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
sbanks01
Post by sbanks01 »
yes I checked fuses don't know how to check relays or know the location for window relay
misha
Post by misha »
Hm...did they both stopped working in the same time?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
sbanks01
Post by sbanks01 »
yes just both windows on driver side
misha
Post by misha »
The only thing that is falling on my mind are fuses.Since they are ok then it must be some relay.
Volvo does not specify which relay is for power windows(i doubt there isn't any),but i think that it must be one of these overload relays on these pdf files:
electrical component locator.pdf
(1.6 MiB) Downloaded 137 times
fuses and circuit breakers.pdf
(121.97 KiB) Downloaded 78 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
sbanks01
Post by sbanks01 »
ok thanks I will look into it
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
misha wrote:Did you checked fuses & relays?
That doesn't track with the problem as stated.
There's one power feed for the window system.
If there was a power supply problem,
none of the windows would work.
This almost has to be the Master switch,
96 850 Power Windows Diagram.pdf
(168.6 KiB) Downloaded 113 times
