1998 S70 T5 Keyless Entry Module ECU ECM 9166198
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
_
Keyless Entry Module Computer Unit ECU ECM 9166198
http://www.ebay.com/itm/251342501748?ss ... 1436.l2649
Purchase an Alarm Module last year and installed it. The Door Locks have been working intermittently. Probably the Door Lock Actuators need some help also.
The question is do I need the Keyless Entry Module above for the Keyless FOB to work and if so where is this Module located? Thanks.
_
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I'm pretty sure it is located on top of the cluster, however, the remote would have to be dealer programmed.
What is going on with the remote?
MoVolvos
Post by MoVolvos »
rspi wrote:I'm pretty sure it is located on top of the cluster, however, the remote would have to be dealer programmed.
I found the guts of the Remote along with the broken Alarm Module in either the Arm Rest Console or Glove Box when I purchased it. The Remote has a new case, battery and both Home Depot and O'Reilly's testers shows it is signaling. That is all I know about the condition of the Remote.
When you say Cluster do you mean the Speedo dash display assembly?
_
rspi
Post by rspi »
Yep, top of the instrument cluster that is under the dash pad with all of the driving info.
MoVolvos
Post by MoVolvos »
rspi wrote:Yep, top of the instrument cluster that is under the dash pad with all of the driving info.
Thanks I'll check to see if it is there.
_
