1996 850 n/a sas pump malfunction
nsmith4815
Year and Model: 1996 850 n/a
Post by nsmith4815 »
I plugged my car in the other day just to check on it and see if everything was running well and I received the code p0410. upon further research I found that this has to do with my secondary air injection system. I also have a misfire on the 4th cylinder and I'm guessing this could be causing it. my question is does anyone know where the issue could be in the system ? I do not currently have a check engine light on but I would like to prevent it.
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
Common failure for these cars. The thing can be removed and a minor change made to the computer or you can replace the pump and check valve. I used a very inexpensive pump and check valve bought through Ebay and they work fine.
The misfire is a separate issue. Pull your plugs or better yet swap them out if very old. Cap, Rotor and wires are a big deal too. Plugs, VOLVO only, Cap/Rotor BOSCH only, wires Bougicord only.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
Search forum for "SAS Delete" using the 99-cent diode from Radio Shack.
