99 XC79 dtc P0237
drfishon
Year and Model: 1999
99 XC79 dtc P0237
Post by drfishon »
Did the lookup on a previous blog and all pointed to the TCV. Replaced with no change. Upon key on the code becomes active. Engine runs smooth. Have check the grounds and powers. Vacuum lines apear to be good with no holes or leaks. MAP cleaned, plugs replaced. Any ideas?
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Post by stephansvolvo »
Under codes here on MVS, the p0237 is a boost sensor, signal too low. Not sure where to point you from there. Good luck.
Troubleshooting low boost
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
