2000 s80 p1610 p1651 p0508
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
masterbaz
Year and Model: s80 2000
Post by masterbaz »
hi, can some one help me out here,
i get these faults when i use the reader,
P1610 ECM-903F Throttle unit, internal fault Faulty signal
P1651 ECM-981A Engine control module (ECM). Intermittent fault Internal fault
P0507 ECM-620A Idle Too much response
sometimes the car says emission system service, then sometimes goes into limp mode.
t07706577227
cars fine otherwise, sometimes drives perfect for days then other times does it daily.
rerobin66
Year and Model: 2000 S80 T6
Been thanked: 2 times
Post by rerobin66 »
check all hoses. some of the little ones hooked to the manifold go bad or come off. also check your charge air pipe that attaches under the manifold they come loose and slip down causing a leak in the system and it causes all kinds of intermittent symptoms.
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
