2005 Volvo S60 door lock problem
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Radaren
Year and Model: 1998 s70
Post by Radaren »
Hi there! :)
I have a little problem with my volvo s60. The manual door lock for with the key doesn't work at all. When i put the key into the hole, and tries to turn it to one of the sides, the lock doesn't move at all. Im not able to turn the key into the door. The same is on the trunk. Do anyone know what i need to do? :)
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Use some penetrating oil and spray inside the lock (not too much).
Insert the key then start trying to turn it slowly back and forth. No need to force, just keep trying to turn it. It will loosen up after a while.
