1995 960 Limited Brakes
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
techedbob
Year and Model: 960 1995
Post by techedbob »
When I depress the brake pedal it goes to the floor. Master Cylinder is full and there are no leaks. Also when sitting at idle the engine starts to sputter. It does not matter if it is in gear or not, when I release the pedal the engine goes back to normal.
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Sounds like a brake booster problem.
1988 Volvo 760 Turbo Wagon
rgk
Year and Model: Gray 88 245
Has thanked: 1 time
Post by rgk »
Perhaps a vacuum leak in the brake booster and air in the brake fluid. When/how did this start happening?
rgk -- was dickdeadly
jimmy57
Been thanked: 320 times
Post by jimmy57 »
You state that it goes to the floor. Does it really go to the floor where pedal is touching carpet or does it just go down an inch or more past initial point where pressure is felt?
