Rear main seal, 1999 S70
olpossum
Year and Model: 03 V70, 99S70
Post by olpossum »
The clutch/throwout bearing/RMS project was coming along, but after removing the flywheel the RMS does not resemble the ones in any photos I've seen anywhere. It looks like it's made of felt, no rubber flange is visible. I'm really having trouble keeping the drill where I want it and can't get a screw to get a grip on any hole I've started. Is there a different type of RMS than the rubber/steel/spring kind? I've searched.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
How did you go with that seal?
The OEM Volvo RMS is that felt deal. I use a combination of prying with a large flat screwdriver and lots of cursing to get them out.
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
I've done the RMS job three times, and every time I've wimped out and asked my mechanic friend to come by and remove it with his seal puller tool. He also did some cursing and mucking about, and we had trouble with the drill.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
