1998 V70AWD Striped Torx screw
flyingswede
Year and Model: V70AWD 1998
Post by flyingswede »
Removing Timing Belt I striped the Torx screw on tensioner. Any ideas. Thanks in advance.
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
If you can get to the bolt with a 90 degree drill and a screw extractor you can get the screw out.
JDS60R
Been thanked: 3 times
Post by JDS60R »
This has happened to many and you are probably concerned with the limited space between the head of the bolt and the frame/apron of the car.
You can use a sharp cold chisel to first bite into the bolt and then angle and tap to remove. Other ways include a dremel bit to cut the sides straight and then use a vice grip or a wrench to remove.
I have a small impact hammer that I use with a sharpened head that works like a power cold chisel. I prefer the thousands of little impacts as it gets them off quickly.
I can't remember if you have enough room to grind the head off and then slip the tensioner off but you can measure and see.
Retired
Dirk1966
Year and Model: V70 2.4 D5 2004
Post by Dirk1966 »
I have used this tool in the past for rounded bolts and screws
Bolt-Grip Bolt Extractor
http://www.ebay.com/itm/Irwin-394001-5p ... ls&vxp=mtr
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
Or use an Angle Grinder with diamond blade ($20) at Menards hardware store and grind the head of the bolt off.
Wear goggles!
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
cn90 wrote:Or use an Angle Grinder with diamond blade ($20) at Menards hardware store and grind the head of the bolt off.
Wear goggles!
The torque on the screw is merely 25Nm.
The aux belt tensioner pulley is synthetic, plastic like.
