'98 S70 Settle the brake bleeding sequence question
dosbricks
Been thanked: 2 times
Post by dosbricks »
'98 S70, 222K: I just finished installing new rotors, pads, and rebuilt calipers and I have a Motive power bleeder to flush the system. After just doing a MVS search on brake bleeding, I find two approaches: farthest to nearest wheel, and nearest to farthest. Both proponents site credible sources. So I post this thread, not to start a debate, but to get the definitive answer.
In the past I have always flushed from farthest to nearest--was that wrong??? Confused but open to all expert advice.
dos
Has thanked: 1500 times
Been thanked: 3810 times
Starting in about 1967 (?) US cars were required to have split (redundant, redundant) brake systems where the hydraulics were isolated. I think most cars now are split front/back but some are split diagonal.
Farthest to nearest certainly makes sense in terms of preventing air from entering.
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
It really doesn't make a lot of difference as there is a brake line to each wheel. I would still go from farthest to nearest.
Klaus
osman
Year and Model: 2002 c70 hardtop
Post by osman »
Always heard farthest to nearest, never the opposite.
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
85 GLH, 367 whp
00 Insight, 72 mpg
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Farthest to nearest; that's how I've always bled mine.
dosbricks
Post by dosbricks »
Thanks guys. It's good to know I've been doing it correctly all these years.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The only time order makes any difference is when the system is dry and you are bleeding it when it has a lot of air in a lot of places. Even then it is not of any consequence unless you are pumping pedal to bleed. In that case going to the longest line and getting the most air out first will make for less wasted master cylinder pump stroke from compressing air and not moving fluid through lines.
Flush bleeding a bled system just to get new fluid throughout is going to happen regardless of the order.
