My over flow tank cracked open and leaked coolant. I replaced the overflow tank and filled . The dash display said coolant low stop safely. The overflow tank is full but the message is still there. Could this be the thermostat or air in the system. Puzzled please help.
Thanks Dave
2003 v70 xc overheated
kinnikin303
- Year and Model: 2003 v70 xc
jimmy57
- Been thanked: 320 times
Bump the tank in few directions to get the float loosened up. Often the float hangs at bottom and a thump will free it. Sometimes floats fail with age and heat and tank has to be replaced.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
or sensor at the bottom of the tank not being attached properly
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Inspect the level sensor electrical connector for cleanliness; a small coolant ingress from the leak may have contaminated the contact pins thus causing a 'false positive'.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
