1999 V70 XC #4 fuse short, no-start. MVSOLVED coil wire
flyingd
Year and Model: 1999 XC V70
Post by flyingd »
Please help. I replaced the spark plugs, timing belt, water pump, valve stem seals and took off the intake manifold to check on the pcv system. got everything back together but now it is blowing the #4 fuse and won't start. What do I need to be looking for. I need to get this car back on the road.
1999 V70 XC 135K
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
What does the fuse protect? look on the card diagram on the fuse flip up cover. my Clinton's only goes up to 98.
flyingd
Post by flyingd »
It protects the fuel and coils. Just don't know why it quit now. It was working before I worked on it.
1999 V70 XC 135K
kahl
Post by kahl »
Take a good look at the wire harness that leads to your injectors. This harness probably has the plastic loom that has rotted out. you should look for chaffed or pinched wires that were disturbed when you moved around the fuel rail and the manifold.
Has thanked: 1502 times
Been thanked: 3817 times
Also the wires to the coils...they get 12VDC constant and are grounded by the ECU to fire. Those wires also rot off the looms and can short.
flyingd
Post by flyingd »
got it......... a wire got crushed when screwing down the ground for the coils. dumb mistake but glad it was found. Thanks for the help
1999 V70 XC 135K
