So my car is a 1991 volvo 245 with M47 transmission. It has LH3.1 and recently It started throwing a 2-1-2 code even though I had recently replaced the O2 sensor. I just replaced it with a non-generic one and I am still getting the 2-1-2 code after driving a mile or 2. I looked at the o2 with the engine running but the o2 not plugged in with a volt meter and am not seeing voltage on it. the green wire from the ECU is giving .45v and the engine does not react to being grounded or being pulled up to .9v
Anyone have a suggestion as to whats going on?
Thanks.
1991 245 LH3.1 o2 sensor issues
Solved, found that the heating element for the o2 was not getting power. I looked at the fuse but never had checked for power at the fuse as I figured I would have a no run/start situation since the fuel pump is on the same fuse. Turns out the fuel pump relay was not function but I was still able to start and drive the car without any noticeable sluggishness. I did replace the pre-pump recently so maybe the new one was supplying enough pressure to operate the fuel injectors.
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
Interesting. Thanks for posting the solution. Need to look at some wiring diagrams and see how you managed to drive the car with a failed fuel pump relay!
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
- 927 Views
Last post by ONV70XC
- 886 Views
Last post by RickHaleParker
