Also, I am having the following issues:
1. The headlights are constantly on, as long as the car is on.
2. The radio display, and driver information center display (real time fuel mileage calculator, message center) are very dim. I initially thought they were in "night time" mode due to the headlights being always on, but even at night you can barely see them.
3. Having trouble shifting from park to drive/reverse unless I park with the emergency brake set before I turn the car off.
4. Cruise control mostly does not work, although it occassionally does. Sometimes it will stay set the entire drive, others only for 15-20 minutes or so, but mostly it does not work at all. My steering wheel radio controls work just fine, and the light on the dash for the cruise control also usually illuminates if I turn the cruise on.
5. Brakes vibrate. Not sure if it's a pad/rotor issue or an ABS issue. Any ideas or feedback?
Thank you in advance for your help. I am not the world's best mechanic by any stretch of the imagination.
