1998 S70 Torque Setting for Front Wheel hub
kevins s70
Year and Model: 2007 XC70
Post by kevins s70 »
I am just replacing a front wheel hub that had play but didn't make any noise! I can't find the torque setting for the four bolts that hold the hub on anywhere. What should it be?? Also would you use threadlocker if the torque is set correctly? There was no thread locked on the bolts i took out and they were quite snug. Thanks
Has thanked: 1507 times
Been thanked: 3824 times
For my 1999 Alldata reports 48 FT lbs torque plus 60 degrees angle tightening.
No Loctite is recommended. This is for the four bolts inboard holding on the wheel bearing hub.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
My manual says 33 ft lbs + 60°.
kevins s70
Which manual says 33 ft/lbs?? I have a Chiltons and it says nothing !
kevins s70
After looking in the manual again I found i. It indicates 33 ft/lbs +60. Thanks
