I'm new to the forum and any help would be greatly appreciated.
We bought my wife an '01 S40 1.9T with 125K mi. When it runs well, its a great car, but it decided to die on us about a month ago. Before it died on us, over the past few months, I changed a number of things that it needed:
Fuel Press Regulator
Fuel Filter
ECT Sensor
Thermostat (also flushed coolant)
Both Front Axles
All 4 Spark Plugs
Ignition coil (dont remember which one)
MAF Sensor
I went to start the car the other day and it would crank but not turnover. Opened the air filter and sprayed some carb cleaner in, car started, stayed on for 5 seconds and shut off. I turned the key to listen to for the fuel pump and didn't hear anything. I went to the fuel press reg and disconnected the line and turned the car on and not a drop of fuel came out.
I am assuming now that the fuel pump is dead, but i do not want to put $400 into a pump and it turn out to be the relay
Is there anything I can do to test for this or any advice anyone can give me before I put a bunch more money into parts that won't solve the issue.
Thanks for any advice,
Larry
