1998 V70XC P410 SAS issue- baffled
OldSkoolMadSkilz
Year and Model: v70XC 1998
Post by OldSkoolMadSkilz »
My 1998 v70xc has thrown a P410 and I'm totally baffled. I started out checking the system at the solenoid located at the top of the radiator. When the engine starts, it does not open. I checked the voltage at the connector and it's only 8.5 volts. If I run a jumper right from the battery to the solenoid, it does open. Must be that 8.5 volts is not enough to open it. I think the SAS relay only is for the air pump itself and the signal for the solenoid come from the ECU, but I could be completely wrong on that. Is it normal that this voltage be low? Engine was "cold", but it was pretty hot outside when I tested it. Don't know if that makes a difference.
TIA
Rob
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
Search forum for the 90-cent diode fix.
OldSkoolMadSkilz
Wow, thanks, I'll try that. Maybe I'll buy two and put one in my Saab to fix the evap code that keeps coming up.
Seaway
Year and Model: 1998 V70 T5 Manual
Post by Seaway »
I got 25 of them on eBay for about $2.50. Pm your address and I will send you a couple. Its an easy fix and worked well for me. I was a little intimidated at first, but it is an easy fix that allowed me to pass inspection. The CEL has been off for a week or so now.
OldSkoolMadSkilz
OK, I'm still baffled. I did the diode fix and so far, no codes posted for 100 miles. However, I can't seem to get readiness set. The sections it didn't set are SAS and O2.
I tried the procedure in TSB 25-19. May not have followed it exactly to the letter. From my house to the next traffic light is about 4 1/2 minutes at 45 mph, so I had to stop before 6 minutes. I also can't guarantee that I kept the tach between 1800 and 2200 the entire time.
Is it possible that the mod is affecting the ability of the ecu reading the last two monitors, or did I mess up the readiness drive?
Jack Rock
Year and Model: 1998 V70R
Post by Jack Rock »
These cars are notorious for taking forever for monitors to be ready. I recently had an EVAP leak that I fixed before my inspection. I commute 45 minutes to work, city and highway, and am constantly on the go and it was not ready for two weeks - I checked ever time I got in.
1997 850 T5 (gave up at 324,000km)
1998 V70 R AWD (gave up at 296,000km)
1998 S70 T5 (total loss - in a parking lot!)
1999 V70XC
1975 VW beetle
1960 Empi Sportster Dune Buggy
Has thanked: 1497 times
Been thanked: 3810 times
My 1999 takes over 300 miles to set EVAP. I eventually researched and found the EPA allows you to pass an emission test with up to 2 monitors not ready. My state, NY, honors this policy. Check with your state DMV for compliance. I passed inspection in May with EVAP not ready.
Seaway
Post by Seaway »
After the diode fix mine would not get to readiness either. Virginia passed me with no problem and it has been working fine for weeks. Now if I could just get the MAF problem sorted.
OldSkoolMadSkilz
JUST PASSED! Maryland makes you wait a week before a retest, so in that time, it came up ready. I went to the test shop armed with MD-VEIP documents stating that certain cars, including mine, were waived from the readiness requirement. It also stated that all cars 2001 and up can have one monitor unready, and 2000 and below, two monitors. They said that was dropped a few years ago. Now they free extensions for retest.
Here's what I don't get. The ECU drops fuel trim settings any time a monitor fails, including SAS. As soon as I did the diode fix, my mileage jumped from 19 to 22. So I figure that on an average drive, I was wasting 15% of my gas. That seems like it would have more environmental impact than slightly higher cold start emissions. I think they should have designed it not to reset fuel trim for SAS failure.
