Volvo 850 Strong odor through vents
Baptiste1106
- Year and Model: 850 1994
- Been thanked: 2 times
I have a strong odor coming through vents. I checked by the turbo to see any visible leaks and nothing. Only thing i can think of is the exhaust manifold gaskets need changing or the manifold is cracked. Any suggestions MVS?
- Has thanked: 2652 times
- Been thanked: 1245 times
Exhaust odor, I take it?
Baptiste1106
@ matthew .... I guess, can't be anything else
Idle with the hood up. Check from there.
Baptiste1106
Engine heat is tremendous with vehicle on and hood open. Idle with hood open, then what?
- Has thanked: 1502 times
- Been thanked: 3817 times
Listen with garden hose around the exhaust manifold for the whoosh Woosh whoosh sound of a leak...
Ben850
- Been thanked: 7 times
Pull the oil dipstick with the engine running and check for smoke.
When I took ownership of my '93 the PCV was severely clogged and the whole car stunk horribly of crankcase fumes. It smells like exhaust and burnt oil.
Also, it had no cabin air filter. I imagine you don't either.
Has the PCV system been done on this car?
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Baptiste1106
@ ben850... Pcv recently done when timing components were changed. Even after pcv change, vehicle still had smoking dipstick. My boy from volvo said the piston rings are worn which causes blow by gases. I also installed the retainer and cabin filter. I used to drive with my dipstick sticking up a lil which the odor was worst, now i just keep it flush with the tube. Gave me and passengers headaches
You may be breathing carbon monoxide when driving.
I know you know this, and you don't need a lecture: Just tell me how to fix the damn thing.
My hood up/idle suggestion was to allow your senses to have at it on pinpointing a location for the leak. Look for exhaust (esp. on start up), sniff around, and listen with a garden hose (good idea, Steve).
Please be careful driving. This is scary stuff IMHO.
Baptiste1106
@ matthew1 ... Thanks for the concern. Trust me i'm not taking this lightly at all. I'm still a lil confused about the garden hose method. I'm new to the forum mechanical terminology so school me teachers. I've done it all to pcv, oil line rebuild, stage 0, etc.... So i'm sure this is some simple thing. Please give step by step instructions on the garden hose method @ abscate @ matthew1
