94 Volvo 850 T5 Tie Rod Stuck to Steering knuckle?
Volvofan94
Year and Model: 2002 Volvo S60 AWD
Post by Volvofan94 »
Hey MVS,
My project this week has been replacing the front lower suspension on my 850 Turbo, but I'm running into an issue removing the passenger outer tie rod end from the steering knuckle.
The theaded part that goes into the steering knuckle doesn't want to separate so I can replace the tie rod end. I've tried many things, liquid wrench, hitting it with a dead blow hammer, putting some heat on the steering knuckle and liquid wrench then hammering, and using a pickle fork. Can't seem to make it budge. :x
Has anyone ran into this issue before? If so, how did you get them separated?
Thanks!
-volvofan94
2002 Volvo S60 AWD - 2.4L I5, 167k miles - Daily Driver
1994 Volvo 850 - 2.3L I5, 160k miles. - SOLD
1994 Volvo 850 - 2.4L I5, 174k miles. - SOLD
Milkmanx
Year and Model: 850 1994
Post by Milkmanx »
I think when I did it I lightly pried on the open slot behind the joint with the bolt removed. When I rebolted the new one back in it closed it back up..
Has thanked: 1497 times
Been thanked: 3810 times
The final solution is to go rent/borrow/buy a press out tool from Advance which will push the end out with threaded force. If that fails, bring it to a shop with a case of beer and have them pop it, grease it, and then reconnect for the trip home.
