I've done the wiring for a driftcar of a friend, he put an 850t5 engine in a 940 rwd chassis. I've removed the boost controller and the evap valve, and all other niggly stuff connected to the engine loom. He's now tried to get it mapped, but it's running VERY rich. I now have 2 questions:
-What can cause it to run VERY rich?
-can I get the ecu codes from the ecu without the normal dataconnector thingy? As in, can I connect a led/12v bulb to 2 pins on the ecu, and get the codes? edit: I'ts the motronic 4.3 one by the way
best regards,
William
