1991 740 Only one fuel pump
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Duhuhude
Year and Model: 740 1991
Post by Duhuhude »
Hello all,
I recently diagnosed and replaced a bad fuel pressure regulator on my 1991 740 wagon (b230f), and now I am trying to change the fuel filter. I know that I am supposed to remove the fuel pump relay, then turn on the engine to empty the lines, then disconnect the filter. When I removed the fuel pump relay, the car did not start, and when I looked under the car, there was no fuel pump, just the filter with one line coming from the tank, the other going to the fuel rail. Is this a problem for changing the filter? Why does my car have only an in-tank fuel pump?
Thanks in advance for your help!
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Maybe it's a Regina car. Bosch LH cars have two pumps. Regina cars only have an in-tank pump.
1988 Volvo 760 Turbo Wagon
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Duhuhude wrote:...then turn on the engine to empty the lines, then disconnect the filter
Wear goggles and just remove fuel filter. I clean threads/pipe before removing, and I have a rag to soak up fuel.
Rex-I/Regina used a single fuel pump in-tank; access via trunk on 4-door models.
There should be a black box on engine firewall, and another box around passenger kick-panel area.
Duhuhude
Post by Duhuhude »
It is indeed a Regina system, I didn't know that Regina cars were only supposed to have one pump.
Thanks for your help, lummert and 93Regina!
93Regina
Post by 93Regina »
Duhuhude wrote:It is indeed a Regina system
Vehicle might also have a lockup torque converter (AW70L or AW71L); on mine, the torque converter lock-up is around 45-mph (72 Km/hr).
Duhuhude
Post by Duhuhude »
I'm pretty sure it's a AW70L with the lockup torque converter. How do I verify this?
93Regina
Post by 93Regina »
Duhuhude wrote:How do I verify this?
The transmission is identified from the product plate on the left-hand side of the unit.
