So I found the source of my massive oil leak. Front intake cam seal. It was out far enough that I just used my fingernail to pull it the rest of the way off the shaft...
I'm assuming a plugged PCV Oil Trap is the cause, so obviously I'll replace that.
What I'm REALLY hoping is that I have no problem with the exhaust cam front seal, because of the VVT pulley on that. From everything I've read, messing with that VVT system can be a real nightmare.
If I DO end up having to replace the exhaust cam front seal, do you have any specific pointers regarding doing the procedure successfully? THANK YOU.
