1998 xc v70 Rear Brake replacement & Retaining clip
acefrehley
- Year and Model: xc v70 1998
Noobie question here. Do the back brake calipers on a 1998 v70 XC contain a retaining clip on the outside? I am about to make my first run at replacing my pads and rotors and couldn't find anything resembling an outside retaining clip or pin to remove prior to loosening the caliper. Thank you in advance.
- Has thanked: 1497 times
- Been thanked: 3809 times
On the inboard side of the caliper are two plastic plugs - you have to pop these off with a screwdriver, then unbolt the caliper with a hex socket key with a 6 inch handle or so, 6 or 7mm IIRC.
acefrehley
That is the problem, I'm not seeing the two plastic plugs.
They could be missing, in which case the caliper bolts will be full of crud. Clean them out with a small screwdriver or an awl
Peter Kriss
Peter Kriss
acefrehley
Looks like mine were very similar to the S80 rear brakes. No pin or caliperbolts. Ended up being the bolt, bracket, nut, bushing configuration. I have it off and I'm rolling along. Thanks for the help. Wanna go wake up Gene?
No, he is still pissed at me for giving you bad info on your brakes...gotta go, Beth is calling...
