2001 S80 Cruise control issue
johnboneske
- Year and Model: 2001 S80
The s80 I recently bought has an issue with the cruise control... Sometimes it doesn't even show up on the instrument cluster on the dash when pushing the button, other times when it is working it just shuts off and it wont re-engage. It seems to me to be an electrical problem, but where to start? Have others had a similar issue??
2001 Volvo S80
1997 Volvo 850 T5
1997 Volvo 850 T5
MyS40T4
- Year and Model: S80 T6 2000
Hello,
I had issues with the cruise control disengaging and not reengaging - it turned out to be the brake position sensor. The wiring connector solder joints in the sensor fail and can be re-soldered once you get into the thing. The sensor is near the brake booster, It's a reasonably well documented issue/repair:
https://www.matthewsvolvosite.com/forums ... 11&t=20166
Cheers,
Chris
Cheers,
Chris
johnboneske
Thank you...I am working on it, but cant seem to figure out how to remove the sensor? I read that I need to bleed off the pressure(by pressing brake pedal till it is hard) and to remove the "C" clip from around it, but damn is it tight in there... How do i get around the master cylinder to remove it??
2001 Volvo S80
1997 Volvo 850 T5
1997 Volvo 850 T5
precopster
- Year and Model: Lots
- Been thanked: 128 times
Clean the perimeter of the sensor with a solvent so you can reveal the clip. Once it's clean you can rotate it to where the gap iis located and then pry it off with a pick tool or jeweller's screwdriver.
johnboneske
ahhh...you can rotate the sensor and clip at the same time? I notice the clip is positioned at the 3 o'clock position, at 9 o'clock would be ALOT better...
its tight in there!!
2001 Volvo S80
1997 Volvo 850 T5
1997 Volvo 850 T5
johnboneske
Thank you for all your help! I got it fixed and it is great!!!
2001 Volvo S80
1997 Volvo 850 T5
1997 Volvo 850 T5
