1999 V70XC - Nautic Blue
Forum rules
Please create one topic per Volvo you own. Then simply post to that topic when you maintain or repair your Volvo. You'll have a nice record of what you did, when, and how much it cost. Only you can post in your topic.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Service------------------------------Mileage--------Parts-------------Labor------------Notes
Purchased Car-------------------122,520--------$1300.00---------$--0.00----------Bad Fuel Pump.
Rented Tow Trailer-------------122,520--------$----57.20---------$--0.00
Replaced Fuel Pump----------122,520--------$-----0.00---------$--0.00----------Used 30 day old pump from V70XC parts car.
Replaced Tires-------------------122,527---------$ 386.21----------$--0.00----------Firestone Affinity Touring.
Replaced Key Antenna-------122,541----------$--42.85----------$--0.00
Post by Ozark Lee »
VIDA/DICE-------------------------122,541--------$-116.20---------$--0.00------------Cleared error codes and started car.
Post by Ozark Lee »
Battery------------------------------122,541--------$--49.25---------$--0.00------------Replaced battery and IMM code came back.
Post by Ozark Lee »
Replaced ECT sensor----------122,541--------$---0.00-----------$--0.00------------Known good from parts car.
Replaced thermostat------------122,541--------$---0.00-----------$--0.00------------Known good from parts car.
Replaced cam sensor----------122,541--------$---0.00-----------$--0.00------------Showed good on a scope but changed it anyway.
Upper radiator hose clamp--122,541--------$---0.00-----------$--0.00------------Broken clamp, replaced with spare parts stock.
Post by Ozark Lee »
Replaced battery cable--------122,541--------$---0.00-----------$--0.00------------Known good from parts car.
Flushed coolant-------------------122,541--------$---0.00-----------$--0.00------------Zerex G05.
Replaced wire looms-----------122,541--------$--38.60-----------$--0.00------------Injectors, battery cable, and coils.
Post by Ozark Lee »
Replaced timing belt------------122,541--------$ 122.78---------$--0.00----------Belt, Idler, & Tensioner.
Post by Ozark Lee »
Service-------------------------------------Mileage--------Parts-------------Labor------------Notes
Replaced Left Control Arm---------------124,928--------$ 89.95---------$--0.00----------Meyle
Replaced Transmission Axle Seal----124,928--------$ 18.95-----------$--0.00----------Corteco
Replaced Lower Radiator Hose-------124,928--------$ 42.88-----------$--0.00----------Dayco
Flushed Coolant-----------------------------124,928---------$ 37.70-----------$--0.00----------Zerex G05
Replaced Axle Bolt-------------------------124,928---------$ 6.62------------$--0.00----------
