1994 850 non turbo transmission fluid
adrian22
Year and Model: s60 2006
Post by adrian22 »
What is the best transmission fluid for ( 1994) nonturbo 850 wagon 144k miles .And where I can buy it. My transmission is working but get a "bump" when changing lower gears
There are any additives I can add to improve it?
Thanks for any suggestions
adrian22
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
I use Dexron III/Mercon. Last time it was Valvoline bought in 1gal containers from Walmart. I did the drain, flush & fill with 3 gallons. I do it every year. I have never used any "fancy" fluids, just basic, proper ATF. I've had my last 850 for 12 years and going...never a shifting issue.
You buy it at any auto parts store, or department store. Have you ever done the drain, flush & fill to your 850 before? How is the level and condition of your tranny fluid now?
'00 S70, '04 S60 and the never ending quest for Stage Zero
adrian22
Post by adrian22 »
Level is ok, color is red not burned, I drain it every 2years and refill with 3 qrt Castrol/Import multi-vehicle automatic transmission fluid
see it here
http://www.autozone.com/autozone/access ... id=5161840
adrian22
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
Although the fluid sounds fine, 3 quarts is not draining very much of it, you may want to do a full flush. I also use whatever cheap Dex III I can find, usually Super tech (yep, Wal-mart house brand). With regular fluid changes, these transmissions are nearly bullet proof. Especially in an NA.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
