Have completely replaced the cooling system, completely rebuilt turbo, cleaned turbo coolant lines, replaced crankcase vent hose and oil trap (pcv service by tech), and new thermostat housing gasket, inlet, and thermostat............problem is when I start it and let it idle......and when I place a rubber glove over oil fill hole......it inflates.
Don't really want to run it a lot till I figure it out......any thoughts or suggestions?
2002 S60 2.4T has positive crankcase pressure
horseguytenn
- Year and Model: S60 2.4T 2002
precopster
- Year and Model: Lots
- Been thanked: 128 times
Do compression check wet and dry. If numbers markedly increase and oil consumption is high you probably have worn cylinder bores.
JRL
- Year and Model: Several
- Been thanked: 16 times
Before he does that he should do a COMPLETE breather replacement, he did not. I wonder if he either has a small cracked hose or the hole into the pan is clogged and was not looked at
precopster
So he should spend another 5 hours, remove the inlet manifold & chase a possible clogged PCV when he can spend 30 minutes on a decisive compression check first?
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 603 times
Then he will spend another 5 hours, because it is indeed PCV. Replacement of oil trap alone gives nothing.precopster wrote:So he should spend another 5 hours, remove the inlet manifold & chase a possible clogged PCV when he can spend 30 minutes on a decisive compression check first?
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
The PCV service was done by a tech, and the crankcase breather hose was replaced as well. Unless the tech has done an incomplete job, I'd do a compression test as well. As said, oil consupmtion, mileage and general condition of the engine would be good indicators.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
vtl
http://www.ipdusa.com/products/4991/115 ... 5-cylinder
PCV kit includes long hairy hose with aluminum tubes and banjo bolts. It costs half of the kit price. It is important to change it too.
Also if the return oil passage is completely clogged, he needs to drop off oil sump and clean it properly.
precopster
How many miles are on this car and does it have a regular oil replacement history?
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 78 times
http://www.volvopartswebstore.com/showA ... evel=11150
Part #13 is a problem area on the turbos. It has a tight passage that clogs and the plastic lines are so brittle it's near impossible to clean it out. Volvo dealers sell a "kit" to replace that part.
horseguytenn
All good stuff!! Many thanks, it has to be somewhere......just eliminate one thing at a time.
Has 118000 miles, and serviced consistently since we owned (since 05). Am a maintenence freak, lol.
- 3335 Views
Last post by Clemens
- 969 Views
Last post by diegotheslinger
