P1171 keep on returning!!
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Re: P1171 keep on returning!!
Sounds like the MAF sensor reading is higher than normal and/or air leaks. Check air intake ducts and hoses. Have the shop chech MAF reading against spec.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
there is this post
http://www.volvo-forums.com/t10577-p1171-code.htm
you mention a map sensor was replaced, did you meant maf? volvo is sensitive to this sensor, original volvo part should be used (even a used one off Ebay should be fine)
