I am not sure what to work on.
I replaced the Heater core 2 years ago after it started leaking a little bit. Took a few hours, but done right.
A/C works good. the 2 lights on ECC control always blinks after start.
Not a resistor problem (new one installed early summer this year without any change on AC or Heater).
when I turn on the Heater, fan starts but slows down immediately to very slow blow. Slider fan speed control doesn't affect much.
What should I look to fix the problem?
Thank you for the helps,
Ihncheol
99 V70XC Heater fan speed problem? AC works fine
PatternFlyer
- Year and Model: 99 V70 XC
- Year and Model: Many Volvos
- Been thanked: 75 times
It might be a problem with the controller but you need VIDA / DICE to scan it and figure it out. You can't just swap out the controller with a used one since it needs a software download.
There is a Volvo shop over on 69 Hwy, Lamar Automotive I think, that might have VIDA / DICE. If you are ever up around KC I would be happy to scan it for you.
- 1681 Views
Last post by volvolugnut
- 3708 Views
Last post by wizechatmgr
