Anyways.. usually a common problem is a leaky vac line to the diaphragm that controls the accel pedal. I checked all that and mine was fine. I did some more searching and found where a guy figured out to add a "pad" to the brake pedal switch and the vac switch connected to the brake pedal that way the switch closes completely and well.. i have cruise control again.
So.. if you have CC issues try adding a pad to your brake switches
