2004 Volvo C70 Meyle tie rod ends question
brick8
Year and Model: 2006 V50 T5
Post by brick8 »
In the process of doing deferred maintenance on my "new" C70. I bought the Meyle tie rod ends from fcp and noticed that there was some grease leaking out of the boots. Is that normal? The joints on them really didn't feel much stiffer than the old tie rod ends that I removed.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
If you squeeze the boots and greese comes out, then the elements would be getting in and you will lose those joints in a short order. (I suppose these are the outer tierods)
Yes, the boots on these like on the lower BJs should feel pretty stout - if otherwise, they won't pass (my) inspection :D
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I can't speak to the Meyle tie rod ends, but the Volvo blue box outer tie rods that I put in about a year ago were not leaking any grease.
I installed a pair of Meyle "HD" anti-sway bar end links about three years ago, and my memory is that they were not leaking grease either.
