06 s 40 Help camshaft
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
lightshinesthrew
Year and Model: 2005 s 40
Post by lightshinesthrew »
hello all,and thank you for all the help I've read threw the years. the gist of my situation.is this timing belt broke of course valves were bent. i had the head done and cams polished. what a mistake.putting everything back together. i got a gut feeling the cam lobes weren't right. even after the marks all lined up. exhaust points 12 o'clock and the intake lobes point roughly 9 o'clock does anyone have pictures of cam cover off and timing belt change for the t5 model. to place my mind at ease.. thanks and bless you
JDS60R
Been thanked: 3 times
Post by JDS60R »
You will need to start by checking part numbers to make sure the right cam is in the correct slot.
Then use cam lock tool to set up VVT and follow attached procedure until the finish.
Hope that helps
S40 06 timing gear and VVT.pdf
(418.76 KiB) Downloaded 329 times
Retired
mf70
Year and Model: V50 2006
Been thanked: 2 times
Post by mf70 »
Slightly off topic Q: What was the mileage when the belt broke? Any other complicating factors?
lightshinesthrew
90,000 miles
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Same cam lobe position and firing order as any other 5 pot whiteblock engine.
The 850 head replacement tutorial has some pics of the lobes you can use on your S40
lightshinesthrew
UPdate .. i finally got the cams correct they were off ,now i'm catching a time with tubing coming from turbo that goes behind motor mount. anyone have any pictures of how to right this piece of aluminum ..
