Got a cracked/busted header down pipe. Looks like it has the ERG setup. When I look around to buy this front pipe, my model and year are conspicuously missing from all available exhaust parts lists. Am I missing something? Like does an 89 244 fit, or is there some other work around?
I appreciate any advice from you guys.
Thanks
I'm new to Volvos, (inherited an 89 six months ago with 105k miles, next week I'm getting a 91 turbo) so looks like I'm into Volvos for a while now!
1989 240DL Exhaust Header
Brickhaus66
- Year and Model: 89 240 DL, 91 940 T
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Terminology is very important. I have looked up a part for the exhaust header.Brickhaus66 wrote:Got a cracked/busted header !
See photo here, and the relevant question is, is it number 2, or 3, or 4.
I have no idea if yours could be welded
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
I would guess you have one just like this replacement from FCP. Make sure the catalytic converter flange is the same - there are two types: fixed (requires triangular gasket), or rotatable (requires metal donut seal - this is most likely what you have).
They have a great return/refund policy, too.
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
Brickhaus66
lummert wrote:What I found indicates Volvo and Starla # 3514976 fits 86-93 242/244 and 86-93 245.
So are you saying that the '89 240DL is the same as the '89 242, 44, and 45?
Brickhaus66
This is my guess too. I have looked at this FCP link before. The picture looks like my part.mtd240 wrote:I would guess you have one just like this replacement from FCP. Make sure the catalytic converter flange is the same - there are two types: fixed (requires triangular gasket), or rotatable (requires metal donut seal - this is most likely what you have).
What's throwing me is at the bottom of that page, it does not list the 240 as one of models that it fits! The lowest model number the header pipe will fit is 244 for an '89, they say a 240 fit for a 1990 year, but my 240 in an 89.
The return policy is a great piece of knowledge. If I can't find an exact fit guarantee (model and year--which I have not so far) somewhere else, I may gamble by ordering it and seeing if it will fit.
Flange: I know that spin or fixed is important. How can you tell the difference? Mine looks like it is separate from the pipe. It's raised with a fine space around the pipe diameter, and not appear to be welded or shaped on the end, but there is no ring seal backing it up.
Brickhaus66
93Regina wrote:Terminology is very important. I have looked up a part for the exhaust header.Brickhaus66 wrote:Got a cracked/busted header !
The answer is: 4. Is there a difference in the gasket between the manifold and the manifold down pipe that I am replacing, depending on where the ERG goes? Or some other reason?
On the cat side it looks to me like a spin flange. Manifold side, it's pin bolt and gasket. Man, am I going to have to soak this part in PB Blaster!
- 16 Replies
- 1602 Views
Last post by FireFox31
- 780 Views
- 1055 Views
Last post by heatdev
- 1099 Views
Last post by rgk
- 3478 Views
Last post by reeltapegone
