1996 850 Pressing red seat belt release button does not work
T64me
Year and Model: 04V70R/05S60R/07S60R
Has thanked: 6 times
Post by T64me »
I have a 96 Volvo 850. When I press the red seat belt release button it does not release the seat belt. I really have to work at it to get the seat belt to release. Any suggestions as to how to fix this issue? Strangely I have the same issue on the driver and passenger side of the car.
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Post by stephansvolvo »
Are you referring to where the metal piece locks in? If it's happening on both sides there maybe a sensor that's the culprit.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
T64me
Post by T64me »
I press the red "button" and it takes a lot of jiggling to get the metal piece to release
Has thanked: 2203 times
Been thanked: 1852 times
They can get 'gummed' up over time causing problems latching or releasing. Shine a torch down them and see if coffee or pop has been spilt down them, as this lets gunge catch in them.
I just had to do this recently on 2 of my seatbelts as the wouldn't latch properly. If this doesn't work, then replace them!! Plenty in auto wreckers.
T64me
Post by T64me »
I was thinking of squirting WE 40 in them to clean any goo out of them. Maybe that would work?
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Has thanked: 17 times
Been thanked: 31 times
Post by cuhfs »
I had that problem 2 times and fixed it. Both times there was a glass chard from a shattered window in the buckle slot the metal piece went into. One was a car I bought that seat belt buckle did not work right. 2nd time I knew about the glass break. Maybe a small foreign object that is hard to see is in there. Like a piece of shattered window?
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
T64me
Post by T64me »
Good input. I will try compressed air.
rhalkyard
Year and Model: 1996 855R
Post by rhalkyard »
T64me wrote:I was thinking of squirting WE 40 in them to clean any goo out of them. Maybe that would work?
I freed mine up with some silicone lubricant spray. Just squirt a tiny bit in there, latch and unlatch the buckle a few times, wiping off the excess each time, and it should free up. WD40 would do the same job, but I've found that it attracts dirt, and will eventually gum up again - silicone is better in that respect, if you have some on hand.
1996 855R in bright red – bought it as a winter beater, then found out how great they are!
Other cars:
2011 VW Golf 2.5 – wife's car, sensible, reliable transportation
1985 VW Scirocco – restoration project
1956 MGA Roadster – rough-around-the-edges open-top fun car
T64me
Post by T64me »
Blew them out with compressed air then squirted some WE 40 in them. Now the work perfectly.
