2005 V70 2.5T AWD - Dies climbing Hills
Paul33
Year and Model: V70 2.5T AWD 2005
Post by Paul33 »
Hi All,
long time reader - first time asker :-)
I have a 2005 2.5 T AWD - about 200k Km (140k miles).
I've just replaced:
maf
PCV
turbo air intake pipe
the pipe the goes over the top of the engine
battery
intercooler air temp sensor (mat I believe)
ETM
on my dash board I have the engine system service message along with the yellow warning sign and engine light.
When I have the error lights turned off they normally stay off for an hour or two and then they're back - seemingly nothing changes (and I'm a little annoyed having just changed the turbo air intake pipe as I thought the sensor was leaking).
I ran VIDA on the car and it reports air leak on the intake side possibly the maf (well the maf is new and everything else is well connected).
So - when I drive on the flat, full car or empty the thing drives well, it kicks down when it should and drives as you'd expect (not a race car but what the hell). I have however noticed that the engine noise has changed slightly and also when I look at the temp gauge it is a little higher than before (the kind of changes that you know when you've been driving a car for a while but nothing anyone else would hear/understand).
The problem however comes when I go up hill with a car full (4 people) - it goes well to start with but then gets to between 2 and 3000 revs and suddenly falters, starts missing, pinking and spluttering. If I then lay off the revs and then rev again it picks up and I can fight it up the hill.
Does anyone have any ideas as my dealership can't find anything and after they changed my ETM instead of cleaning it I'm having doubts about them.
Thanks in advance,
Paul.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Find this air leak. MAF reports X of air entered the car, other pressure sensor sees less air, which can't happen if the intake is properly sealed.
