1998 S70 T5 Flashing Service Light
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
A couple days ago I left my dome light on overnight and killed the battery. I gave it a trickle charge overnight and put it back in the car this morning. On my way to work everything was fine, but on my way home after about 2 miles into my 20 mile commute, the service light started to flash, the speedometer wouldn't work and my temp and fuel gauge were erratic. I have 15 gallons in the tank and it took about 30 minutes for the gauge to read properly Once I got home I disconnected the battery for about 15 minutes and when I reconnected it the problem went away. Any thoughts on this? I was thinking maybe the ABS module? Any help would be appreciated.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Because of the set-up for the issue-dome light, dead battery, partial charge, I would suspect that the battery was not fully charged. Flashing CEL indicates a misfire. ABS module relies on steady power to run. Have you checked the codes yet? Temp and fuel gauge sounds like a power or ground interruption. They all relate back to electrical. How's your key switch? Check threads on that. Make sure your battery gets a FULL charge. You may have had a bad connection, since disconnect-reconnect reset it, or it may be lurking?!
EDIT-you say your service light is flashing-disregard mention of CEL I still say it leans toward battery and cabling.
Current Volvos:
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
That's the flashing light of death for the instrument cluster.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
shaker_chi
My CEL did not go on. The only light flashing was the "service" light, thus no codes to pull.
Matty Moo
That's what I'm talking about. The only time the "service" light will flash is when there's a fault with the instrument cluster.
2000 s70 GLT
2014 Ram
- Year and Model: Many Volvos
- Been thanked: 76 times
A bunch of people have had that problem and the solution seems to be to remove the service light which I would recommend anyway.
When repairing the odometer gears I always take the service light out and stomp on it, just to make sure it can't make its way back to the car somehow. It is as a result of some sort of internal fault in the cluster but, other than the light flashing, many of the clusters continue to operate otherwise.
It seems to be more prevalent on the 850 clusters and the 70 series clusters but it can happen to both.
- 153 Views
- 126 Views
- 704 Views
Last post by gdict
- 628 Views
Last post by jmartin919
- 30 Replies
- 7419 Views
Last post by goldmandan
