94 850 turbo what should vacuum gauge read
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
Using torque on my tablet and wonder what the vacuum readings should be at idle and when driving, I get around 23 at idle and down to zero at near full throttle- I assume the zero is correct but I have been wrong before
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Those torque apps do not work properly. The car does not report the data to the OBD2 port.
Ben850
- Been thanked: 7 times
I have that app. and it does read the boost level, and vacuum very close to accurate albeit with a slight lag time in communication, through the OBDII port.rspi wrote:Those torque apps do not work properly. The car does not report the data to the OBD2 port.
I have since installed a quality, digital/analog boost gauge and had watched them both simultaneously.
The readings were almost identical, aside from the lag.
I am not saying it is a professional piece of gear to bet your best dollar on, just a reference.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- 12 Replies
- 3246 Views
Last post by polskamafia mjl
- 494 Views
Last post by paul850
