Hello, fellow Volvonians.
My 01 S60 5MT has been treating me great, however, I have recently run into a weird problem. Coincidentally, this exact thing happened this time last year to my old Honda Civic. Regardless, here's the issue...
Car starts and runs fine @ idle. When I go to accelerate, the engine runs strong (no drop in RPMs), however in each gear (shortly after shifting), the car seems to pulse/jerk/stutter for a bit until more RPMs are added. This sensation seems more apparent at low speeds and higher gears, such as 5th Gear @ 30mph, 2-4 at 15-30mph. The car is showing no codes either on my OBD-II scanner.
To me, it feels like the brakes pulsing on their own, I hear a "thumping" pulse kind of noise (if that makes sense.) I've made a list of all the possible things to check (CV, wheel speed sensor, ign coil, etc.) However, I really want to see if there is a known issue with this particular model. What do you guys think could be the issue? She is going into my mech. next week, as this feels a bit above my level.
Thanks!
2001 S60 5MT Base Pulse/Jerk During Acceleration
WarbirdPilot91
- Year and Model: 2001 S60 Base
WarbirdPilot91
It jerks when clutch it both engaged and not engaged
WarbirdPilot91
It does not, which has me puzzled...lol. Would it help if I got a vid of it?chrism wrote:When it stutters, does the the tach jump up and down like the engine is missing?
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
After I asked that I realized you have a manual trans. So any engine missing probably wouldn't have a big effect on the indicated RPMs, as long as the clutch is still engaged, like an auto trans would.
I would be tempted to rig a fuel pressure gauge to the injector rail and tape the gauge to the windshield so that I could see, real time, if there's a drop in pressure that correlates with the stuttering. At least then you could either realize a problem in fuel delivery or eliminate that possibility which cuts your diagnostic effort in half. That's how I diagnosed a bad fuel pressure sensor that was causing a miss but wasn't triggering the CEL.
How old are the spark plugs? For about $12 you can pop a set of new copper cores in there. A bad spark plug tends to rear its ugly head when the engine is under heavy acceleration and not so much when it's sitting there idling.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
was the fuel pressure sensor replaced? (recall)
may also inspect spark plugs as mentioned, fuel filter (if plastic gas tank), spark plugs, clogged injectors, vacuum hoses
WarbirdPilot91
Good idea on the fuel pressure tester, I will explore that option! The plugs are about 2-3 months old, I recently replaced them along with ignition coils. I could check to see if any are faulting, but the last time one did, the CEL engaged (hence the reason why I changed everything, LOL.)chrism wrote:After I asked that I realized you have a manual trans. So any engine missing probably wouldn't have a big effect on the indicated RPMs, as long as the clutch is still engaged, like an auto trans would.
WarbirdPilot91
I will check the fuel pressure, the fuel pump was replaced before I bought the car last May, but I do not know if they did the filter as well. Which vacuum hoses should I check/how? (Pardon my ignorance.)oragex wrote:was the fuel pressure sensor replaced? (recall)
WarbirdPilot91
Here's a crappy vid of it, lmao. Anyhow, anytime the camera shakes or you hear that rattle noise, that is the jerking/pulsing I am referring to. Notice the RPMs seem steady, nothing erratic.
- 853 Views
Last post by bubisamongus
- 2194 Views
Last post by JRL
- 1590 Views
Last post by vtl
- 35 Replies
- 8364 Views
Last post by arrrxivvv
- 1370 Views
Last post by sbattaglia
