My daughters 1998 S70 had a leak on the lower transmission line coming off the radiator. I replaced the seals with IPDs transmission line kit but the leak persists and it leaks at a greater rate. Should I replace the hose, the radiator, or both? Could I plug the ports for the transmission cooler and just delete it?
2005 V70R
2000 C70 HPT Convertible
1998 V70 T5
1998 S70 Base
1998 S70 Lower transmission line leaking after seal R&R
- Been thanked: 504 times
Try this...
DIY: 1998 S70 GLT Trans Cooler Line Rebuild for $10!
https://www.matthewsvolvosite.com/forums ... hp?t=55794
BTW, use the O-rings from dealer only.
