premium gas?
- Has thanked: 17 times
- Been thanked: 35 times
I have a T5 and use Premium (93 is highest they have around here) because the owner's manual recommends it....and it's more FUN!
White850Turbo
- Year and Model:
The car will run fine on the lower grade, but if you've got a lead foot, get the highest octane available. The octane rating of gasoline is its resistance to detonate (ignite from heat and pressure in the cylinder before spark from the spark plug ever reaches it). This is bad for the engine. This is why modern cars w/ EFI use knock sensors to detect detonation. When detonation is detected, the knock sensors will send a signal to the ECU and ignition timing or boost and/or add more fuel (depending on whether one is working with Motronic 4.3, Motronic 4.4, or ME7) will be retarded to prevent further detonation. The higher the octane, the less likely it is to detonate, and in turn, the more power the car is able to make safely.
-Sean
1998 S70 T5 (Almost Stock)
- Tsquared
- Year and Model: 11 C30
- Has thanked: 1 time
Use the lowest octane that will not ping. If you hear pining or valves rattling wile you are accelerating or going up a hill you need to get a higher octane.
Our 850 runs great on 87 octane. My F150 and Electraglide require 89 octane. The 944Turbo needs a bottle of octane boost in with the 91 octane and 1/2 bottle with 93 octane.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
- 20 Replies
- 4695 Views
Last post by SleeStak69
- 2282 Views
Last post by djtomr941
- 886 Views
Last post by E Showell
- 27 Replies
- 4731 Views
Last post by erikv11
- 2627 Views
Last post by jimmy57
