1997 Volvo 850 R smoke/steam out of oil filler cap?
I have a '97 volvo 850 R with 185,000 miles. ive owned it for 2 months and synthetic oil is used in it but i havent changed the oil yet. when i opened the oil filler cap today just after i drove it, smoke or steam came out of it. i checked the dipstick and there was white sort of gunky stuff on it. what is that? would an oil change fix that?
- Been thanked: 504 times
Change oil and filter using Mann or Mahle.
Then lift the dipstick upward about 2 or 3mm while you do some reading on PCV overhaul. I wrote a mod using 5/8 inch heater hose.
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Heater core hose can't withstand oil for long. Use hoses rated for oil only.cn90 wrote: I wrote a mod using 5/8 inch heater hose.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
there's a pcv test shown on Youtube
is there also steam forcing out of the dipstick tube?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Let's calm down a bit guys -- you mean you've never seen vapor escaping from the oil filler cap on opening a hot engine? I'd consider that perfectly normal. Before we send "hours" racing to do a PCV service don't you think he might try the balloon on the dipstick tube test to see if there is positive crankcase pressure?
Hours -- remove dipstick, place balloon over dipstick tube. Start engine and allow to idle. Balloon should not inflate. If it does, you most likely have a clogged PCV (Positive Crankcase Ventilation) system that will require servicing. Another test for this, again, with dipstick removed, is to see if you get smoke rising from the dipstick tube. If so, you have positive crankcase pressure -- not good. That has been known to blow out cam seals, rear main seals, etc. if neglected too long.
If you have positive crankcase pressure and need to drive the car for a bit until you can service the PCV system, then leave the dipstick loose -- don't seat it all the way -- and drive like that. The unsealed dipstick tube will allow some crankcase pressure to vent, but service the PCV asap. There is a detailed, extensive write up on here for performing that service. It isn't an easy job -- mostly time consuming -- but it can be done on a DIY basis if you're a confident amateur wrench and can follow simple directions (available from this site). Allow six hours for the job if it is your first time, although you might do it in less time than that.
I'm guessing it is a $600 job parts and labor if you have a local independent Volvo specialist do it (but I don't know how many independent Volvo specialists there are in China, or what mechanic's hourly labor rates might be).
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Redneck
- Year and Model: Volvo 854 1996 GLT
- Has thanked: 10 times
Volvo is now owned by a Chinese car company. Since most parts are made in China, it may be a very good place to own Volvo and get parts for a ridiculously cheap price. Mechanic's work must be really cheap too.
@hours, can you tell us where we can buy some good Volvo parts online for a great price directly from China?
You need to do your PCV, but use the correct Volvo OEM hoses.
precopster
- Year and Model: Lots
- Been thanked: 128 times
I just replaced the PCV on a '99 V70 NA yesterday with 274K kilometres on original PCV that had considerable positive pressure; so much pressure that it was leaking engine oil all over the top of the engine even with a new cap seal!!
I purchased the IPD kit which contains all items needed including intake gasket, dipstick o ring and injector o rings. The PCV parts were genuine Volvo and the intake gasket was aftermarket. They threw in a set of quality screw clamps as well.
I was really careful about cleaning out the ports with doubled up thin wire and compressed air.
The repair went so well that when I pulled the dipstick I heard a huge rush of air and I thought it was heading out of the engine. Upon doing the rubber glove test there was so much vacuum it could have suck started a Harley!! Great result
- 1250 Views
Last post by instarx
- 1525 Views
Last post by Sommerfeldt
- 753 Views
Last post by tryingbe
- 3895 Views
Last post by E Showell
- 1416 Views
Last post by bmdubya1198
