2003 s60 awd considering purchase, things to consider...
mrscullini
- Year and Model: 05 XC70, 08 XC70
- Has thanked: 1 time
found what appears to be a clean car. this will be to replace my recently departed 2000 v70xc. anything special to be concerned about on this model? i assume the same trusty 5 cylinder. was the awd updated by this model year?
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 604 times
Engine may be even better (what year they replaced 2.4 by 2.5?), check if clogged PCV causes leaks through seals. AWD is Haldex-based, may have problems with bevel gear and pump. Our beloved AW55 transmission can be a problem as well.
mrscullini
thanks vtl. i think it is the 2.5 litre. anyway to do a cursory check on the bevel gear?vtl wrote:Engine may be even better (what year they replaced 2.4 by 2.5?), check if clogged PCV causes leaks through seals. AWD is Haldex-based, may have problems with bevel gear and pump. Our beloved AW55 transmission can be a problem as well.
vtl
Check if AWD is working at all: collar sleeve may be stripped. Bevel gear is often leaking, you'll need to split it and reseal, there's tech.note from Volvo how to do that. Check the play in pinion bearings on driveshaft side (try to move driveshaft up-down near bevel gear). Also the driveshaft itself may have dry CV bearing ($300 in parts) and dry carrier bearing (new driveshaft...).mrscullini wrote:anyway to do a cursory check on the bevel gear?
All fluids need to be changed ASAP, of course: bevel gear, rear diff, Haldex. Haldex also has two filters, one of them is sort of replaceable.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
2002-2003 also had the dim issue, hopefully the owner did fix it already
check warm transmission under hard acceleration for smooth 2nd to 3rd gear shifting
look into the service papers see if the pcv was replaced
precopster
- Year and Model: Lots
- Been thanked: 128 times
S60 AWD was the first to receive Haldex in 2002 before the XC70s were bestowed in 2003.
mrscullini
thanks guys. i've been on the hunt for a car since my beloved v70xc died. don't really want to crack the $10k mark. i appreciate all the insight. gonna post on a 2008 i found, please feel free to chime in.
thanks again!
thanks again!
mrscullini
the 2008 s60 i was hunting fell through. looking at an '03 again. what's the "dim issue"?oragex wrote:2002-2003 also had the dim issue, hopefully the owner did fix it already
- 867 Views
Last post by cn90
- 594 Views
Last post by precopster
