1997 850 overheating
- Has thanked: 311 times
- Been thanked: 817 times
Agreed, could be a head gasket, it could also be as simple as a leaky cap on the reservoir, has the cap ever been changed?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Remove the cap from expansion dish and let the engine idle.Wait untill it reach operating temperature and wait untill cooling fan kicks in.
Maybe you have air trapped in the system after recent radiator & water pump replacement.
If this not help,then you have a bad headgasket or replacement water pump is bad.
Did the car overheat before water pump replacement?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
If coolant boils in exp. tank that means the cooling system is not pressurized. The pressure in cooling system prevents coolant to boil at 100 deg. Celsius. That said your system has leaks somewhere, most common places are, like said, rad. cap, hose clamps, water pp. If your engine starts, idles and runs okay your headgasket is good. However, the overheating needs fixed fast otherwise hg will go bad.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
misha wrote:Remove the cap from expansion dish and let the engine idle.Wait until it reach operating temperature and wait until cooling fan kicks in. [watch fluid circulating through the expansion tank - practice safety!]
Misha's method works for releasing trapped air.
You may want to run few cycles.
I prefer using Volvo's fluid for few $ more.
Was the thermostat ever replaced? ...Sensor?
Yes, the car was overheated badly and almost died on the road two days after I took it back from the painter's. The expansion tank was all brown and the mechanic found a blockage at the tiny hose on the tank. He flushed the radiator and put in several gallons of water. The cap on the expansion tank was not changed but he recommended to change the water pump. It was not leaking before that. He said the trapped air has been released. After that the temperature gauge is on midpoint and stays there when I drive but the engine oil and abs lights keep coming on and off. There is a vibration which can be felt on the steering wheel. My new set of volvo spark plugs were soaked in oil. I have them cleaned and put them back. It starts fine now with much less noise from the engine but the expansion tank still hisses after a short drive. I'm just wondering if the oil pump or switch that's triggering the oil lamp or is it the ignition switch. I didn't have these problems before the car was left in the paintshop for three weeks. The first time I drove out of the painter's I felt something wrong with the car, it seemed to rattle on reverse gear. The painter told me he opened the bonnet and flushed the engine compartment with water and cleaned the wheels with some polish and liquid chemicals. Could he have caused some damage with water and chemicals leaking into the brakes? The abs lights stayed on permanently for a couple of days, now its coming on and off randomly.
- 1771 Views
Last post by ZionXIX
- 1892 Views
Last post by dmg4
- 502 Views
Last post by jeremykentucky
- 30 Replies
- 8938 Views
Last post by erikv11
- 966 Views
