the car has about 145k on it. we have not had one issue with the car since we bought it from jrl with about 96k on it, it has been a great car.
on the highway this afternoon running at about 70 mph, 3000 rpm. idle got a little erratic, cel flashed a few times and power dropped. pulled off the highway, idle was a little rough. happened to have my scanner with me, pulled a p300, 302 and 304. cleared the codes restarted the car, seemed to idle smoothly so i drove home about 40 miles with no problem.
any thoughts? i will pull the plugs and check each cylinder tomorrow.
2005 xc70 misfire, cylinders 2 and 4
mrscullini
- Year and Model: 05 XC70, 08 XC70
- Has thanked: 1 time
mrscullini
this morning all seems normal. no pending codes, idles smooth at about 650 warmed, revs up smoothly. will pull the coils/plugs this afternoon.
is there a way to simply test coils with a multi-meter?
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
Could you hook up a scanner to read fuel trims, o2 sensors, and maf signals? Also do you lose coolant? There's no good way to test coils with regular meter. Coils are step up transformers and when they fail they develop leaks secondary to primary so you'd need an insulation test. You could try the ohm meteron it's highest scale and measure between the pipe and any of primary wires, but probably reading will be infinity.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
mrscullini
Thx draser. I'll see if my scanner has o2, maf capability. It is an autel us703.
What should those readings be?
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
you could also swap the coils around to different cylinders and see if the misfire follows the suspected coils.
Jesse
Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
mrscullini
thanks guys. the misfire is gone, it's now running "normal". no codes, no pending codes after a few drive cycles today.
here are some numbers i pulled with the scanner. no idea if they are in a normal range. numbers were pulled after about a 20 minute drive at 60 mph and idling in the garage.
ECT= 95 degrees C
IAT= 50 degrees C
Spark Adv= -1.5 deg to 3.0 deg
MAF= 2.69 to 2.83 g/s
RPM= 659 to 676
O2B1S2= 0.09 to 0.745 V
O2S11= -0.137 to 0.07 mA
CATTSM= 336
any insight is much appreciated.
ECT= 95 degrees C
IAT= 50 degrees C
RPM= 659 to 676
CATTSM= 336
draser
MAF is similar to mine, o2 sensor 2 has normal levels, all others are normal values. For a misfire is good to know fuel trims to determine if engine runs lean or rich. For a normal running engine fuel trims will bounce around zero. Any change in mpg?
mrscullini
thanks. no change in mileage. what are the fuel trim abbreviations or notations on the scanner? i will check them.draser wrote:MAF is similar to mine, o2 sensor 2 has normal levels, all others are normal values. For a misfire is good to know fuel trims to determine if engine runs lean or rich. For a normal running engine fuel trims will bounce around zero. Any change in mpg?
mrscullini
i've got the following, not sure it is the fuel trim..draser wrote:MAF is similar to mine, o2 sensor 2 has normal levels, all others are normal values. For a misfire is good to know fuel trims to determine if engine runs lean or rich. For a normal running engine fuel trims will bounce around zero. Any change in mpg?
fuelsys1= cl
fuelsys2= -(dash)
draser
Short term fuel trim -STFT, long term - LTFT. Can you inspect coil connector for 2, 4 to make sure wiring is good condition, conn clean - maybe spray some cleaner?
- 19 Replies
- 10154 Views
Last post by Barledge
- 1345 Views
- 930 Views
Last post by stephansvolvo
- 1734 Views
Last post by freebirdchampion
- 14 Replies
- 2718 Views
Last post by ToriWhite
