After I took car from him (still hot) it was running really nice, next day in the morning it simply failed to start and showed two codes:
P1238
P0171
I tried to hold it running by pressing throttle (as I used to do before) but it failed to work. I cleaned MAF, still the same. I decided to unplug it completely and surprisingly it starts fine. Maybe not fine, but at least I can drive it. Seems to be in limp mode now, ETS light is on along with CEL, however no stalling or RPM hunting. After I start it it goes up to 1400 RPM to stabilize around 950-1000 seconds later.
What do you guys think? Should I fix my ETM in the first place or try to knock out my error codes first? Thanks!
My suspects:
- MAF, I cleaned it using CRC MAF Cleaner. From what I remember values were rather fine on idle. Can't verify it know because it won't start when it's plugged in
- O2 Sensor
- Air leak? I think he at least eliminated all of those, however I plan to run dummy smoke test to see if anything comes up.
- Dirty fuel filter/fuel pump issues?
