2003 V70 Whiny noise from engine at low gears
f97ao
Year and Model: V70 2003
Post by f97ao »
Hi,
I bought a V70 from 2003 a few weeks ago and from what I could see everything was in order, good service history and drove well etc.
But now when I'm driving I hear a low high pitched "whine" on the low gears.
- It sounds very synthetic, almost like a police syren. "eeeeeeeee"
- the pitch changes when I switch gear. I only hear it when driving on the first or second gear.
- the volume is very low, but its audible. If I had the radio on I don't think I would hear it at all.
- I mostly hear it when the car has been cold, it seems to go away when the engine gets warm.
Does anyone know what this could be?
Thanks,
Andreas
Has thanked: 1609 times
Been thanked: 4064 times
Search under the hood with a garden hose and listen for the power steering pump and alternator bearing at idle. Have some one lightly rev the motor while you do this.
I'm guessing its a engine speed related noise that you can hear at higher car speeds and not related to the transmission speed.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
First guess is serpentine belt tensioner. Its bearing dries out faster than anything else sitting under same belt. Tensioner is somewhat expensive, but you can replace only pulley with bearing, was like $20 for me.
