Different tire size in front & rear will it work?
nitink
Post by nitink »
I have purchased a used 16" rim set. The tire on them in front is 205/40/16 and in rear is 205/55/16. Rear tires are about 2.5" bigger than front.
Can any one please suggest if I can use this configuration of different front & rear size tires, or will it damage suspension.
1995 Volvo 850, Non Turbo
95300 miles
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Don't see how it would damage anything unless you have AWD and you don't. Fronts are the same size and although different, rears are the same. Strange, yes, but damaging, no. Now if the fronts or rears were different sizes L and R, then it could cause suspension issues.
pfeener
Been thanked: 2 times
Post by pfeener »
Not a great idea, but it won't damage anything. The front and rear tires turn independently. The front tires have to be the same size, but other than that it won't damage anything. Handling might be a little "funky". I wouldn't do any aggressive driving.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2664 times
Been thanked: 1256 times
Post by matthew1 »
It might mess with the car's ABS computer. Wheels will appear to be going different speeds.
I don't know how such a scenario would play out, i.e.: if it would trigger ABS braking whenever you brake, the ABS light on the dash, or both.
Also -> Amazon link
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Not a great idea, in fact on a FWD car, if anything, the FRONTS should be bigger
saltydog
Post by saltydog »
??????? guarenteed ABS/TRACS light & codes. Why would you do that? :shock:
spawn of satan 2001 XC70 Brown (how appropriate)
96 850 turbo wagon - come back please
86 740 turbo wagon RIP
84 240 turbo wagon RIP
nitink
Post by nitink »
Ok I won't try this stunt.
I got rims with different tires mounted on them, and wasn't looking to spend money on tires. I will just bite the bullet and buy 2 new tires of 205/40/16.
95300 miles
JRL
Post by JRL »
nitink wrote:Ok I won't try this stunt.
No no NO !!!
NOT 205/40/16 completely the wrong size
Stock is 203'55'16 you can go lower with 205/50 16
I've never heard of a 205/40/16 anyway, does anyone even make this weird size?
JRL wrote:
nitink wrote: Stock is 203'55'16 you can go lower with 205/50 16
No, no....205/55/16...not 203.
Actually, it was originally 205/50/16 on the 850 turbo's (with Columba's) but too many bent rims with the low profile tires and so Volvo changed it to the 55 size.
JRL
Post by JRL »
Of course 205, typo, there is no 203. Do you have to comment on EVERYTHING obvious?
...and he obviously wants a LOW profile
