98 S70 T5 Oil in Coolant
volvo_bruh
- Year and Model: S70 T5 1998
I've been having a slight coolant leak from under the car and I noticed the coolant in my coolant resevoir is pretty dirty and maybe some coolant in my oil on my last oil change which was about 300-400 miles ago. My oil wasn't milky and isn't now. My low coolant light came on today so I topped it off and checked under the car for the possible problem. I found what i believe to be a cooling hose leaking. It appers to run from the radiator to the block. I don't think I have a bad head. No white smoke and the car runs fine. Just wondering if this could be a possible cause to my oil+coolant problem. Thank you for any feedback.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Just fix the coolant leak and keep rolling. "Stop Coolant Roulette".
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
Pre-'99 turbo cars have an oil cooler in the radiator. It's basically a series of tubes carrying oil through the coolant. That is prone to cracking, and the oil seeps through the cracks into the coolant.
volvo_bruh
So replace the radiator and the leaky oil cooler line?
j-dawg
Yes, the oil cooler is integrated, so just replace the radiator. Read up on the oil line fittings before starting the repair. And yeah, like Robert said, it's never a good idea to let leaky hoses leak.
A caveat: I have a 99 and don't have the oil cooler, so I've never experienced this. But on older turbo cars, a leaky oil cooler is a pretty common problem.
j-dawg
Right, yeah. And the automatics still have a heat exchanger in the radiator. But we lucky children don't have to deal with the oil lines or cracked oil cooler. Not that it matters, because the plastic radiator tanks crack and we end up having to replace our radiators anyway.Azik09 wrote:Post-'99 turbo cars have an oil cooler too. It's mounted on the oil sump.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Usually you will get a leaky rad before any oil or trans cooler breach.... At least from my reading and personnel experience
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- 4500 Views
Last post by rspi
- 1430 Views
Last post by JDS60R
- 2552 Views
Last post by SuperHerman
- 293 Views
Last post by MoVolvos
- 1275 Views
Last post by jonesg
