Hey all,
So after doing my front cam seals, timing belt, water pump and so on I've now put about 50 miles on out xc70. I've noticed there is a small drops of coolant coming from the car, initially I suspected the pump since I replaced it but it seems to be coming from a strange place, the small plastic join on passenger side right behind the fog light so way forward of the pump. It's an impossible area to get a good look at without removing stuff but anyone have any tips where to start?
When I drained radiator I remember fluid dripping from that side as well as the normal drain hole but I figured that was because the car was on stands and tilted backwards so it got into the plastic bumper... I was hoping it was just a pooled up area in the bumper but after 50 miles there is still drops hanging from the plastic. I've had the bumper off before and I think I'll start there but wanted to get an opinion if I should just drive a bit more, maybe rinse out before I start investigating.
Cheers!
2003 XC70 Small coolant leak
- Been thanked: 4063 times
It could be a small leak in the radiator or hose which is making its way into the plastic tray before coming out on the pass side. Keep a close eye on the reservoir to gauge the loss rate...both to quantify and to see if it changes
Both of these seem like good ideas. Do you have a splash guard? If so, when you take it off and lift the car up, can you see more wetness? I'm also thinking if the leak is super slow, it may be your petcock??
- regent
- Has thanked: 2 times
- Been thanked: 12 times
I think you can shove a small inspection mirror in there and verify where the source is before taking the whole car apart
If it is the petcock, DO NOT OVERTIGHTEN - the plastic is very brittle. You may be able to take the petcock out and just clean the seat to stop the leak or replace the petcock (the new one comes with the o-ring for about $3.50). Tighten with a S13 mm socket by hand ONLY
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- GBS
- Year and Model: XC70 2003, V70 2002
I don't think its the petcock as its dry on that side. There was just one drop yesterday so I'm writing it up to coolant left over in bumper from splash when draining. I have a spare for when my petcock breaks off, probably should just put that on there and eliminate that fear as it does no good in my parts bin... live and learn right. Still no oil or fluids from under the timing belt cover so that's good news too.
- 390 Views
- 1615 Views
- 502 Views
Last post by yanga001
- 1104 Views
Last post by neworleans
- 735 Views
Last post by pedal2metal
